KICKR CORE 2 With Zwift Cog And Click
Choose your version
CA$899.99
Wahoo KICKR CORE 2 with Zwift Cog and Click unlocks a world of indoor cycling fun and fitness. With Zwift Cog pre‑installed, it has everything you need to achieve your goals—plus, it’s compatible with almost any 8‑13‑speed bike.
New Features
  • New! Includes one month free trial of Zwift (new customers only)
  • Power Accuracy: +/- 2%
  • Maximum Power Output: 1800W
  • Zwift Click controls your virtual gears from any handlebar
  • Precision flywheel technology matches resistance to the grade of the virtual road
Complete your setup
KICKR CORE 2 only
Total CA$899.99
Zwift Ready
KICKR CORE 2
KICKR CORE 2
Universal Compatibility
Zwift Cog fits almost any 8-13-speed bike, keeping maintenance to a minimum—just jump on and start riding.
Flexible, easy set‑up
KICKR CORE 2's simplified four-bolt assembly and color-coded leg components streamline setup and ensure a secure, stable build for your hardest sprints.
Real Ride Feel
KICKR CORE 2 uses precision flywheel technology and advanced algorithms to automatically match resistance to the grade of the virtual road—so every climb and descent feels real.
Virtual Shifting
Zwift Click controls your virtual gears and attaches seamlessly to any handlebar, turning your bike into a smart bike with quiet, smooth, and consistent shifting.
Your ride. Your way.
KICKR CORE 2 with Zwift Cog and Click accommodates almost any 8-13-speed bike to maximize compatibility and minimize set-up. Whether you have multiple bikes or multiple riders, this is a seamless solution to get everyone in the house Zwifting.
Max Grade Simulation
10%
12%
16%
20%
Min Grade Simulation
-10%
-12%
-15%
-20%
Max Power (Watts)
1000w
1500w
1800w
2200w
KICKR CORE 2 Features
Controlled resistance
WiFi & Bluetooth Connectivity
KICKR Bridge
Professional grade durability
Race Mode
Race Mode
Updated LED System
Updated LED System
Connectivity
WiFi
Bluetooth Up to 3 Connections
ANT plus ANT+, ANT+ FE-C
1800 Watt
Max Power Output
Accuracy +/- 2% Power
Accuracy
16%
Maximum Incline
-10%
Maximum Decline
Belt Drive
Drivetrain
Product Weight
30 lb / 13.6 kg
Resistance Type
Electromagnetic
Cassette
Pre-installed Zwift Cog
Hub Types
Adapters
Maximum Rider Weight
250 lb / 113 kg
Zwift Click
What’s in the Box
  • KICKR CORE 2 Smart Bike Trainer
  • Drive Side Adapter for Quick Release
  • Reversible hub spacer for 130 mm and 135 mm Quick Release
  • Non‑Drive Side Adapters for 12x142 and 12x148
  • Drive Side Adapter for Thru Axle
  • AC Power Adapter
  • Zwift Cog (pre‑installed)
  • Zwift Click
Supported Devices
Your KICKR ride companion
How this bundle compares to CORE Zwift One, what Race Mode does, and what the box includes.
What's the difference between KICKR Core 2 with Zwift Cog and Click and KICKR CORE Zwift One?
The KICKR CORE Zwift One has been updated to the KICKR CORE 2 with Zwift Cog and Click. The new model adds Wi-Fi, Race Mode, KICKR Bridge, redesigned legs, and multi-color LEDs.
What is Race Mode?
What bikes and drivetrains is KICKR CORE 2 with Zwift Cog and Click compatible with?
Designed for versatility, the CORE 2 works with most road, gravel, and mountain bikes, ensuring seamless integration into diverse setups. Out of the box, it supports Shimano HG freehubs for 8–12 speed cassettes, with optional freehub bodies for SRAM XD/XDR or Campagnolo (excluding Shimano Micro Spline and Campagnolo N3W 13-speed). It comes in three configurations: with an 11-speed cassette, with Zwift Cog and Click for virtual shifting, or cassette-ready. Hub support includes 130/135mm quick release and 12x142/148mm thru-axles.
Does KICKR CORE 2 with Zwift Cog and Click include a Zwift Membership?
The KICKR Core 2 with Zwift Cog and Click includes a one month free trial for new Zwift customers.  After the free trial, Zwift access requires a subscription.
Compare smart trainers
CA$1,324.99
Accuracy
Accuracy +/- 1%
Wireless Firmware Updates
Max Power Wattage 2200 Watts
Simulated Gradient
Zwift Cog & Click
Zwift Cog & Click Compatible
KICKR CLIMB Compatible
ERG Easy Ramp ERG Easy Ramp
RaceMode
RaceMode
KICKR Core 2
KICKR CORE 2
CA$899.99
Accuracy
Accuracy +/- 2%
Max Power Wattage 1800 Watts
Simulated Gradient
Zwift Cog & Click
RaceMode
RaceMode
CA$1,149.99
Accuracy
*onboard power available
Max Power Wattage 1500 Watts
Simulated Gradient
3 items
KICKR CORE 2
