BIKE TRAINER ACCESSORIES
LEVEL UP YOUR SETUP
Make your indoor cycling the most realistic and immersive experience with Wahoo KICKR bike trainer accessories. From experiential indoor bike training accessories to mimic the ride positioning and sensations of cycling outside, to more functional items to setup your training space, we've got the bike trainer accessories to build the setup for your goals and riding style.
Shop All Bike Trainer Accessories
EXPLORE ACCESSORIES
Shop All
KICKR CLIMB Indoor Grade Simulator
CA$979.99
KICKR CLIMB
KICKR CLIMB
CA$979.99
BUY NOW LEARN MORE
KICKR Headwind Bluetooth Fan
CA$409.99
KICKR Headwind
KICKR Headwind
CA$409.99
BUY NOW LEARN MORE
KICKR Indoor Cycling Desk
CA$479.99
KICKR Desk
KICKR Desk
CA$479.99
BUY NOW LEARN MORE
KICKR Trainer Floormat
CA$104.99
KICKR Mat
KICKR Mat
CA$104.99
BUY NOW LEARN MORE
KICKR CLIMB
Elevate your ride feel with the KICKR CLIMB Indoor Grade Simulator. Designed to simulate ascents of up to 20% and descents of -10%, KICKR CLIMB blends physical grade changes with resistance changes of the KICKR bike trainers, to make your indoor rides as immersive and engaging as possible.
SHOP NOW
KICKR HEADWIND
Control your climate, your way, with the first smart fan built for cyclists, by cyclists. KICKR HEADWIND pairs directly to your smart trainer, heart rate monitor or speed sensor to gauge workout intensity and automatically adjust.
SHOP NOW
KICKR DESK
Designed for function and convenience, KICKR DESK is an adjustable, rolling desk. Equipped with non-slip surface and technology ports to keep everything easily at your fingertips while you train.
SHOP NOW
KICKR MAT
The multi-functional KICKR MAT catches sweat, insulates noise and provides a soft place to step after a hard indoor ride.
SHOP NOW
KICKR CLIMB BENEFITS
ELEVATED RIDE FEEL
Climbing workouts and virtual courses are now more realistic than ever as the KICKR CLIMB recreates the grade changes in real time up to 20% and descents of -10%.
POWER POSITION
The KICKR CLIMB physically adjusts your bike position to mimic real roads and mountain climbing. This allows you to naturally change position on the bike, engage climbing muscles, and improve pedaling technique while indoors, to become a more efficient and powerful climber outdoors.
RIDE ENGAGED
Connect to the most popular online training platforms to create a truly immersive ride experience. KICKR CLIMB blends physical grade changes with resistance changes of the KICKR Smart Trainers to take your indoor ride to the next level.
KICKR CLIMB FEATURES
LOCK & UNLOCK MODES
Using the retractable remote, you can set KICKR CLIMB to lock or unlock mode. Unlock mode allows the CLIMB to automatically react to grade changes from your device or software, whereas Lock mode only responds to manual commands from the remote.
COMPATIBLE WITH MOST BIKES
DIRECT PROXIMITY PAIRING
KICKR CLIMB’s remote makes it quick and easy to pair the device with your Wahoo KICKR smart bike trainer and get riding!
ECOSYSTEM COMPATIBLE
Your KICKR and KICKR CLIMB system can be connected to your ELEMNT GPS device, as well as the other KICKR Trainer Accessories to create the most immersive and engaging indoor riding experience.
KICKR CLIMB
INDOOR GRADE SIMULATOR
CA$979.99
BUY
TECH SPECS
  • Part Number: WFBKTR5
  • Max Incline: 20%
  • Max Decline: -10%
  • *Exact grade changes dependent on bicycle size, wheel size and trainer type.
  • Compatible Trainers: Wahoo Smart Trainers (KICKR, KICKR CORE, and KICKR SNAP) 2017 Edition and newer
  • Metrics: Current Grade
  • Dimensions: 25.75" H x 5.1" W x 7" L
  • Max User Weight: 250lbs // 114 kg
  • 3rd Party App Compatible: Yes, when paired to a Wahoo smart trainer
WHAT’S IN THE BOX?
  • KICKR CLIMB Unit
  • Power Adapter
  • Adapters for quick release, 12x100, 15x100, and 15x110 Hubs
SUPPORTED DEVICES
The KICKR CLIMB works exclusively with the following Wahoo Smart Trainers:
  • KICKR V6 Released September 2022
  • KICKR V5 Edition released August 2020
  • KICKR 2018 Edition released July 2018
  • KICKR 2017 Edition released August 2017
  • KICKR CORE: Edition released July 2018
  • KICKR SNAP: Edition released July 2017
Please confirm KICKR CLIMB compatibility before purchasing.
KICKR HEADWIND BENEFITS
POWERFUL AIRFLOW
KICKR HEADWIND’s variable speed vortex fan is capable of reaching wind speeds experienced while speeding down the open road, delivering the high velocity cooling needed to stay comfortable during the toughest indoor workouts.
WORKOUT CONTROLLED
KICKR HEADWIND pairs directly with smart trainers, heart rate monitors, and speed sensors to gauge workout intensity and automatically adjusts fan speed based on your efforts. Or simply control the fan manually to set your ideal fan speed.
RIDER OPTIMIZED
The Targeted Airflow Pattern of KICKR HEADWIND is designed to tunnel the fan's airflow at your body, where you need it most and provides a superior outdoor feel - indoors.
KICKR HEADWIND FEATURES
TARGETED HIGH SPEED AIRFLOW
Designed by cyclists, HEADWIND Targeted Airflow Pattern mimics a rider’s body position when on the bike. The powerful vortex fan delivers wind speeds topping out over 30 mph.
MANUAL FAN SPEEDS
KICKR HEADWIND can also be preprogrammed to 4 different fan speeds to allow you to select the perfect airflow for you at the push of a button.
CONTROLLED FAN SPEEDS
KICKR HEADWIND can be controlled automatically via ANT+ speed sensor, heart rate monitor or smart trainer, as well as via the Wahoo App for control at your fingertips.
KICKR HEADWIND’s front legs are specifically designed to latch onto KICKR DESK to allow you to roll the fan into position when adjusting your KICKR DESK while on the trainer.
KICKR HEADWIND
BLUETOOTH FAN
CA$409.99
BUY
TECH SPECS
  • Part Number: WFBKTR7
  • Motor Spec: 120v 60hz
  • Dimensions (leg tucked): 16"L x 12"W x 19"H
  • Dimensions (leg extended): 18"L x 12"W x 19"H
  • Weight: 12 lb / 5.5 kg
  • Max Fan Speed: 30 mph/48 kph
  • Connectivity:
    • Bluetooth - Pair to phone to control the fan speed via app
    • ANT+ - Pair to speed sensor, heart rate monitor, or smart trainer to control fan speed
  • Adjustable Leg: Yes - 2 Positions
WHAT’S IN THE BOX?
  • KICKR HEADWIND Unit
KICKR DESK FEATURES
FULLY ADJUSTABLE
Adjust to sitting, riding or standing height depending on your activity.
EASY TO MOVE
Built on wheels, KICKR DESK is easy to move whether on or off the bike.
TECH FRIENDLY
Features built-in tablet and smartphone stands and holes to connect all your tech as well as a non-slip desk surface to ensure they don't go anywhere.
KICKR DESK serves as an essential indoor bike training accessory to hold all your tech and nutrition while you ride.
KICKR INDOOR
CYCLING DESK
CA$479.99
BUY
TECH SPECS
  • Base (Width x Depth): 28" x 30" (71 x 76 cm)
  • Desk Top (Width x Depth): 28" x 14" (71 x 36 cm)
  • Adjustable Desk Height (from floor): 33"" to 48"" (84 to 122 cm)
WHAT’S IN THE BOX?
  • Desk table top
  • Removable non-slip table mat
  • Adjustable legs
  • Lower frame with Wheels
  • Hex assembly wrenches (2)
  • Assembly Instructions
KICKR MAT FEATURES
ANTI-SLIP WATER RESISTANT MATERIAL
The 6P free PVC material of the KICKR floormat protects your floors from sweat and spilled water bottles, as well as keeps your trainer in place during your toughest efforts.
DURABLE DESIGN
The thick cushion design with beveled edges keeps the mat in line with the floor and sturdy enough to last you many a training seasons.
NOISE INSULATION
The cushioned material of KICKR MAT reduces noise making the KICKR even quieter.
KICKR MAT serves as an essential indoor bike training accessory for any athlete's indoor training setup.
KICKR TRAINER
FLOORMAT
CA$104.99
BUY
KICKR Bike Trainer Floormat
TECH SPECS
  • Size: 36" x 78" (91 cm x 198 cm)
  • Thickness: 6mm
  • Water Rating: Water Resistant
  • Material: 6P free PVC
WHAT’S IN THE BOX?
  • KICKR Floormat
