RPM Cycling Sensor Bundle
CA$114.99
All you need for cycling data, all together at once! The Wahoo RPM Speed and Cadence sensors are both a sleek, wireless, and magnet-less solution. Each mounts easily to your bike and the Bluetooth Smart and ANT+ duel band technology allows you to connect and display data on both smartphone and bike computers.
This product is out of stock.
Dual Band Technology
Wireless Connection
Sleek, Lightweight Design
It only weighs 7 grams!
Cadence Measurement
Provides accurate cadence data during your ride
Peloton iOS Compatibility
RPM Cadence easily pairs with the Peloton Digital iOS App via Bluetooth to get real time cadence data during your spin workouts.
Two Bike Mount Options
The RPM Cadence sensor has two bike mount options: (1) mount with double sided 3M tape, or (2) use the silicone sleeve and mount with zip ties.
Shoe Mount Option
The RPM can be worn on your shoe for spin classes or use with multiple bikes
Hub Mount
RPM Speed mounts on most front wheel hubs with a secure silicon casing.
Visible Connection
Two LED lights show the sensor's device connection (blue) and cadence detection (red)
Replaceable Battery
No charging required! Operates on a coin cell battery for up to 1 years.
Universal Fit
RPM cadence sensor will fit with most bikes and frame sizes
What's Included?
For RPM Cadence
  • RPM Cadence sensor CR 2032 Battery (installed)
  • Rubber Mounting Option
  • Zipties
  • Shoe Mount Option
  • 3M double sided tape
  • Quick Start Guide
For RPM Speed
  • RPM Speed sensor CR 2032 Battery (installed)
  • Hub Mounting Option
  • Quick Start Guide
Tech Specs
For both RPM Cadence and RPM Speed
  • Part Number: WFRPMC
  • Dimensions (LxWxH): 1.25" x.75" x 1"
  • Weight: 7 grams (without mount)
  • Battery: CR2032
  • Wireless Signal Strength: Up to 10 feet
  • *Note: Speed Sensor is NOT compatible with spin bikes
