CA$1,149.99
  • FEATURES
    • View More
  • SPECS
    • Maximum Power Output: 1500W
    • 10% Simulated Incline
    • View More
  • SETUP
    • Some assembly required
    • Compatible with all drivetrains
    • Smooth tread pattern recommended
    • Setup Instructions
  • View More
  • View More
KICKR ROLLR Benefits
Stable and able
The front safety tire gripper can accommodate tires up to 2.1"" (53mm) to keep your bike upright and secure, making it easy to get on and off the bike while providing stability, even when sprinting. Check bike compatibility for more details.
Simple Setup
Dual-Roller design
Optimized flywheel technology
Ready. Set. Roll
KICKR ROLLR's convenient design makes it easy to transition your ride from outdoors to indoors. Simply adjust the wheel base, secure your bike and ride.
max grade simulation
10% 12% 16% 20%
max power (watts)
1500w 1800w 2200w
KICKR ROLLR Features
AWARD WINNING DUAL ROLLER DESIGN
The dual-roller design frees up the rear wheel to move naturally, providing an experience that feels more like riding outdoors while reducing tire slip, no matter how much power you put to the pedals. This unique design has been awarded:
  • Fit Sport Design Award Winner 2023
  • Good Design Award Winner 2023
  • Fast Company Innovation by Design 2023 Award Winner
  • IDA Design Awards, 2023 Gold
  • IDEA (International Design Excellence Awards) 2023 Silver Winner
DUAL ROLLER DESIGN
CONTROLLED RESISTANCE
When connected to an external power meter (not included), KICKR ROLLR provides controlled resistance in level, ERG and simulated modes. Without a connected power meter, the smart bike roller delivers consistent resistance and broadcasts speed metrics.
QUICK-ADJUST WHEELBASE CLAMP
Quickly transition from outdoor rides to indoor cycling. Simply open the quick-adjust wheelbase clamp and adjust the wheel chocks to match your bike's wheelbase: ideal for riders with multiple bikes or households with multiple riders.
RIDE WITH POWER
KICKR ROLLR lets you train with power, without needing to connect a power meter. Ride virtual routes in the Wahoo app, or follow structured workouts with consistent power feedback — great for staying motivated and improving fitness.*
*Power readings are consistent when using the same equipment, but they aren’t designed for racing or comparing across devices. For riders who need precise, race-ready data, KICKR ROLLR supports Power Meter Connect to use your bike’s power meter instead.
ECOSYSTEM COMPATIBLE
KICKR ROLLR bike roller is compatible with KICKR Trainer Accessories, including the KICKR HEADWIND Smart Fan and KICKR Desk, allowing you to build the ideal setup for your indoor cycling needs.
KICKR ROLLR specs
TECH SPECS
  • Maximum Power Output: 1500 Watts
  • Maximum Simulated Grade: 10%
  • Product Weight: 50 lb / 23 kg
  • Drivetrain: N/A
  • Power Accuracy: Within +/-1% of external power meter (not included)
  • Connectivity: ANT+, ANT+ FE-C, Bluetooth, Direct Connect
  • Cassette: N/A
  • Hub Types: N/A
  • Adapters: N/A
WHAT’S IN THE BOX?
  • AC Power Adapter
  • Owner's Manual
SUPPORTED DEVICES
Bike compatibility
BIKE COMPATIBILITY CHECK
Start
FAQ
How Much Space Do I Need for KICKR ROLLR?
Is KICKR ROLLR Compatible with Zwift?
Do You Need a Power Meter for Kicker ROLLR?
The Wahoo KICKR ROLLR offers versatile functionality to match your training needs. Use it right out of the box as premium rollers with built-in power measurement, no external power meter required. The integrated power provides controlled resistance, ERG mode for structured workouts, and seamless integration with Zwift, TrainerRoad, and SYSTM. Power readings stay consistent within your setup. For ultimate accuracy and race-ready data, KICKR ROLLR pairs seamlessly with your bike's power meter through Power Meter Connect, letting you choose between convenience and precision based on your training goals.
How Do You Maintain KICKR ROLLR?
Setting up your Wahoo KICKR ROLLR is refreshingly simple. Start by unfolding the front assembly on a level surface, connecting the rear section with the quick-release lever and securing screws. Adjust the wheelbase clamp to match your bike (950-1100mm compatible), place your front wheel in the stabilizing block, and position the rear wheel on the rollers. Fine-tune the Tire Gripper knob for your preferred stability level. Connect the power adapter for full resistance capabilities, then pair with the Wahoo app for firmware updates and configuration. No spindown calibration needed, the ROLLR relies on your power meter's calibration, making setup faster than traditional trainers.
No modifications needed! The Wahoo KICKR ROLLR is designed for your bike exactly as it is, no wheel removal, cassette changes, or thru-axle adjustments required. Simply place your bike on the rollers and ride. It accommodates wheelbases from 950-1100mm and tires up to 2.1" (53mm) wide, working perfectly with standard road tires (no trainer-specific tire needed). Compatible with both disc and rim brake bikes, the ROLLR's zero-modification design means you can seamlessly transition from indoor training to outdoor rides in seconds. Add a power meter anytime to unlock advanced smart features. No other changes necessary.
